Sd-08 code flashed then went away
MDGFLHR
Windsor Maine
2011 Apex SE
Pulled sled into trailer from working on it in the garage. Went to back up the sled a little in the trailer and code sd-08 flashed. Put it back in forward after I backed up a couple feet and code went away and didn't come back. Is this something I should be prepared for and something is wrong like no reverse? I fired sled back up a half hour later put it in reverse and no code. The reverse actuator going bad? Thoughts? First issue I've ever had with this sled has 2300 miles.
