SD-84 Code, rear wheels, magnetic tether
AAD
Age
50
Canada
Canada
SRX
I cut the zip tie holding the throttle cable to the riser as it was pulling on throttle cable while turning also checked the cable adjuster by riser but it is already adjusted fully loose and I’m still getting this code on brand new Sidewinder.
Should I adjust cable near throttle bodies so I get 2-3mm of slack in throttle cable and then try it out again?
I also rotated the thumb throttle down a little to make it more comfortable read that this could be the reason for throwing a code but I hope not.
Also noticed the 3 rear wheels in skid are all plastic no rubber on them is this new for 2019?
Will the new magnetic tether from Cat work on new Sidewinder?
I see the rear wheel being a problem with studs. J&T Products has a brand new complete 4 wheel heavy duty kit being tested and will be for sale within a week.
Lossened cable almost one turn at throttle bodies and no error code now.
