princesledalot
- Feb 8, 2006
- East Pouce
- 04 RX1 13 apex se 96 vmax 4 aerocharged
- Pouce Coupe BC
My starter piled up last year. While trying to get it to run I adjusted throttle cable, plus had hit the key about 40 times, so may be flooded. New starter is in but sled runs like it's missing and is rich. Code 84 goes away at about 4000 rpm . Sled won't idle and I have to have it about half throttle to run. Any help would be great.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
First thing I would do is go thru all the tests in the ecu diagnostics
princesledalot
- Feb 8, 2006
- East Pouce
- Pouce Coupe BC
Yeah you bet, I gotta find that info you sent me, I think it explains how to troubleshoot.
zx4ever
- Apr 14, 2011
Also start by disabling the tors to check to see if that is the problem. It’s the black and white connectors in the wiring pocket above the clutch switch these to black to white.
princesledalot
- Feb 8, 2006
- East Pouce
- Pouce Coupe BC
TORS is bypassed, code is gone but running pig rich and won't idle. Will run at half throttle but very rich. Might replace spark plugs.Also start by disabling the tors to check to see if that is the problem. It’s the black and white connectors in the wiring pocket above the clutch switch these to black to white.
zx4ever
- Apr 14, 2011
Did you get it figured yet ?
Renaud
- Dec 3, 2024
- Gaspé
- Apex 2009 gt lt-x
Same problème as me!?My starter piled up last year. While trying to get it to run I adjusted throttle cable, plus had hit the key about 40 times, so may be flooded. New starter is in but sled runs like it's missing and is rich. Code 84 goes away at about 4000 rpm . Sled won't idle and I have to have it about half throttle to run. Any help would be great.
Renaud
- Dec 3, 2024
- Gaspé
- Apex 2009 gt lt-x
Did you found the problème ?My starter piled up last year. While trying to get it to run I adjusted throttle cable, plus had hit the key about 40 times, so may be flooded. New starter is in but sled runs like it's missing and is rich. Code 84 goes away at about 4000 rpm . Sled won't idle and I have to have it about half throttle to run. Any help would be great.
Renaud
- Dec 3, 2024
- Gaspé
- Apex 2009 gt lt-x
You think inverse black and white plugin disabling tors??Also start by disabling the tors to check to see if that is the problem. It’s the black and white connectors in the wiring pocket above the clutch switch these to black to white.
