Yeller
Taking the sleds out of summer storage tomorrow and I picked up some seafoam to add to the gas to help clean out the carbs. I ran fuel stabilizer through them in the spring then drained the carbs but I'm adding seafoam just to make sure everything is clear. On the can it says treats 30-95 liters. How much do you guys add to a half or full tank of fuel?
PJVMAX
One ounce per gallon is what I use in all my gas cans.
RX1Jim
I would use 1 to 2 ozs per gallon. This chemical seems to do a good job cleaning the entire fuel system. 1 oz is equivalent to 30 ml.
Yeller
Thanks for the info. Jim, I appreciate the conversion
SledFreak
- Feb 7, 2005
- Ontario. Canada
rik said:Thanks for the info. Jim, I appreciate the conversion![]()
Where can I buy some of this seafoam.. I think I need it for my new Mini Z. It seems to have a hard time staying idling and I believe it has never been serviced properly in the spring and winter, so I'm betting the carb may be a little varnished..
canadianhunter
I think Napa has it in Canada.
RX1Jim
I have found Seafoam in the NAPA auto parts stores, Advance Auto Parts stores, local auto parts stores and even Walmart had it in their automotive section for a few months. If your auto parts store does not carry it, perhaps they can order it for you.
HRD2PLZ
Yep, just seen it in Walmart too, the other day.
here in canada, napa is the easyest place to get it.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I've seen it in Menards too. In the Lawn and garden section with the lawn mower stuff..
apltx08
SledFreak said:Where can I buy some of this seafoam.. I think I need it for my new Mini Z. It seems to have a hard time staying idling and I believe it has never been serviced properly in the spring and winter, so I'm betting the carb may be a little varnished..
CARQUEST in Canada have the full line of products sell around $10.00
420ATTAK
i work at a napa store in ingersoll ontario we stock a couple cases at a time GREAT STUFF best i have found does everythinh but rebuild your carbs or motor. we have to order it by the case (24 cans) at a time. use it to stabilize next time.
XDooMan
sleddheadd
You guys may want to give this stuff a try! Amsoil P.I. Performace Improver. Several customers have used this and claimed it to be better than Sea Foam! It might be worth a look in to!? https://www.amsoil.com/catalog.aspx?cat ... zo=1130379
- 7K
