Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
Noticed the differance last week. My seat is rubbing and tearing along the overhang on the tunnel. Newer apexes have the seat up off the tunnel and have an extra mount or cover in the rear. I am thinking of adding some height to my 2010 seat to match my mtn taller bars so I was wondering if I can raise the seat up? install new mount? or maybe the guys in blue have already done it on the newer sleds's Has any one tried this?
Let me know what you guys think? Mine is the Black pic,Blue pic is the 2013 and notice how the seat is up off the tunnel !
sk-rx1
Anything can be done but I don't see it as being easy. The 2 seats mount very differently, the new ones bolt down thru the tunnel, the old one sort of ties to the back behind the tail light. Also, in the front they hook under the gas tank, if you raised the seat I don't know how you would make it hook under the tank. Seems like it would be a lot of fabricating.....
MarkRTX
Just a note bro my 2011 Apex SE has seat wear in the same place as yours I believe. Still happens with the newer ones too. Got mine used so not 100% sure if something else might have caused it but sure looks like the same wear I've seen on other Apexes.
Daranello
Suspended
2011 Apex 10,000km no seat wear...just had it off too
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
i have the same issue as you.
please post pics of what you do and how you did it.
i am planning a seat overhaul this summer and am looking into any and every idea possible to improve my seat
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
Thanks for the input guys, I was thinking of just raising the back area of the seat? I plan on taking the seat off and checking out soon. Other wise I will just add extra foam to were I sit the most toward the back. 2 inches higher should be about right. On my 03 RX1 I added 2 in and it made it perfect and just stretched the factory seat cover. I will let you know what I try and or find.
Thanks again
Terry
Thanks again
Terry
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
if you just raise the back wont you have a horrible looking gap where the seat meets the exhaust covers?
i tried cushioning the area where it rubs the tunnel and wears the seat cover with adhesive backed high density foam.
it made no difference.
my seat is actually wearing into my tunnel.
sx7001
- Jun 28, 2003
- Sidewinder
sk-rx1 said:Anything can be done but I don't see it as being easy. The 2 seats mount very differently, the new ones bolt down thru the tunnel, the old one sort of ties to the back behind the tail light. Also, in the front they hook under the gas tank, if you raised the seat I don't know how you would make it hook under the tank. Seems like it would be a lot of fabricating.....
Yes, totally different with the new being way easier. I just timed it, 30secs and the seat is off, 2 bolts in the trunk that secure the seat to the muffler heat shield and its off......
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
RTX, It looks like they already did that in the newer models see the blue pic above. The seat my be molded a little differant. I just hate having the seat rub and tear every season plus I want more height.
Sx7001, sounds great maybe I can mount mine that way if i need too> Could you post some pics of the difference,
Terry
Terry
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
repaired seat yesterday, added 1 inch of foam to my seat ( Had it on hand) stretched and stapled added some extra material on the sides were it had pulled apart. Should be good for the rest of the season. sorry didn't get pics of seat repair but will take one of finished top of the seat on the sled soon. Even 1 in of foam seems to of improved the rider height and more but cush !
