DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Below is according to Cat service manual. Should be same as Yamaha.
"Seat heater elements cannot be tested."
To do a resistance test:
1. Disconnect the main harness/element connector.
2. Connect one ohmmeter lead to the red/black main harness wire; then connect the other ohmmeter lead to the green/red main harness wire. The meter must read the following, plus or minus 5%:
Lo = 4.32k ohms
Hi = 3.75k ohms
Note: If resistance is not within specification, troubleshoot the switch connector located under the steering support plastic panel. If the switch connector tests good, replace the switch.
To test voltage:
Note: For this procedure, test the main harness side of the connector, NOT the element side of the connector.
2. Connect one ohmmeter lead to the red/black main harness wire; then connect the other meter lead to the black main harness wire.
3. Start the engine. The meter must read 12-15 volts.
Note: If this voltage test does not read within specification, troubleshoot the main harness, F-2 fuse, K-2 relay, or the F-7 main fuse.
Thanks for this.
My fathers seat element was toast. I purchased a replacement from Royal Distributing for $96 tax in. Its a nice unit, comes with everything you need and the element appears to be tougher than OEM. It also has a connection for heated clothing. I'd recommend it for those that need a new seat element.
DMCTurbo
- Nov 12, 2005
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Can the oem switch be used (hi /low)
Mine has been broke since the first season I bought the sled
DMCTurbo
- Nov 12, 2005
The element is either on or off, it doesn't have hi or lo which to me doesn't matter as on my seat low gets too hot anyway.Can the oem switch be used (ho /low)
I suppose you could use the stock switch on the hi setting. I'm going to use the stock wires feeding the stock switch and tie into the new switch as I don't want to hack into the new seat element wiring. If your familiar with the gears heated riding clothing the wiring/connections are identical.
DMCTurbo
- Nov 12, 2005
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Awsome ty!!! I will order one too since I need to reupholster my seat to match my wrap
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I just put one in my seat Marc! Nice unit and like dmc said it looks pretty robust. I ordered a handle bar lighted switch from amazon for. Never liked the stock location on my viper https://www.amazon.ca/dp/B07YZL9RNQ/ref=cm_sw_r_sms_c_api_i_p6XYEbH7BPPNP
