BoostBoy21
- Jan 20, 2023
- Jackson Michigan
- 2021 Sidewinder XTX LE 146
Hey guys i have a 21 yamaha sidewinder i will be deleting the ROV while i am doing my DMC Gear and pads along with new RTV on the oil tank from the pressure buildup. Wondering if it would be okay to remove the ROV heater and all the hose from the sled. Will i get a code having an uplugged wire for that heater? Would rather not leave it plugged in and mounted. Thanks in advanced!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
You can remove the heated ROV wires. You will not get a code from doing so. I did this also. I used the wires for a AFR gauge.. But most disconnect the heated ROV wires and wrap them up. Obviously not touching each other.. Wrap up in electrical tape.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Also maybe post your stuff in the Sidewinder section instead of general.. Your a Sidewinder guy now!. Welcome
BoostBoy21
- Jan 20, 2023
- Jackson Michigan
That is a good idea! I have a manual boost gauge i need to wire up as well so this makes that easier for me with that idea! Thanks jonlafon1You can remove the heated ROV wires. You will not get a code from doing so. I did this also. I used the wires for a AFR gauge.. But most disconnect the heated ROV wires and wrap them up. Obviously not touching each other.. Wrap up in electrical tape.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Great. I run the KOSO wide band off the Heated ROV wires with a inline fuse.. Been perfect for 2500 miles on my 2022.
BoostBoy21
- Jan 20, 2023
- Jackson Michigan
Roger that man. I am still new to the website and am learning my way to navigate through all the threads lol. I found the sidewinder forum all good now!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Tons of good guys on here with better knowledge then most dealersRoger that man. I am still new to the website and am learning my way to navigate through all the threads lol. I found the sidewinder forum all good now!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
As long as the brass heater part doesn't ground out, it won't get warm, correct? This is from a 2025. Not sure if the earlier ones were different.You can remove the heated ROV wires. You will not get a code from doing so. I did this also. I used the wires for a AFR gauge.. But most disconnect the heated ROV wires and wrap them up. Obviously not touching each other.. Wrap up in electrical tape.
- 13K
- 53K
