kotapug
Can you tell me how to get the seat off? Thanks
Yamaha Man
There are 3 bolts that hold onto the rear exhaust cap...then there are two phillips (#3) head screws by the rear light. After you take them out...then whole light and plastic assembly will clip out. Then there are 2 bolts you will see that hold down the seat. Unbolt them and the seat is off! O and also...theres a wire harness with a connector on the right side of the sled...near the gas tank. Un connect that once you start go move the seat off.
Hope this helps!
Yamaha Man
Hope this helps!
Yamaha Man
kotapug
thanks
NY AttakGT
Keep in mind, only two of the 4 or 5mm allen head bolts come out of the exhaust caps. One of the bolts stays in there, as it is bolted from the back side.
--Steve (O.C.)
--Steve (O.C.)
