secondary cluch help
brad
Waconia minnesota
2004 rx warrior secondary clutch threw two of the ramps out. When it did this , some of the casting behind one of the ramps broke away too. long story short it was way cheaper to buy a new used secondary, than to fix mine and buy three new ramps at $16.00 each. Now my question is... my old one has a gray mark on the spring ,and the new one has a pink mark on the spring. Do I need to swap the springs out? what is the difference if any? The new clutch is supposed to be off the same machine. :
I think the color is silver not gray and the other is pink the pink is a stronger spring you can use either one.
Stiffer spring will up shift slower and may not shift all the way out holding the primary back.
