T-Bone
I noticed today that when I grab the secondary clutch and try to rotate it with the sled on the ground, I can get about 12 o'clock to 1 o'clock rotational movement (freeplay) on the clutch shaft and brake roter. Is this normal or do I have a problem in the chaincase?
sherlock29
Normal... if you have reverse... both mine do it.. thought the same thing..
AttakSnow2
- Aug 17, 2005
- Merrill, WI and White Pine, MI
- Yamaha Viper
X2, I have 2 RX's and 2 Apex's they all do it.
T-Bone
Thanks for the help guys.
