wayfastkev
Has anybody moved the cam and spring from A-1 (stock FX) to B-1 (Mountain lite)? Will it let it shift quicker or slower?
Any info would be greatly appreciated.
2007FX with Ulmer clutch kit and 1.5" freeride track.
i have and will report on it ASAP...havnt riden it yet like this....i put a 1.75x136 track on....tighter setting delays the opening of secondary
B1 works great with my 17tooth top gear, ulmer kit and 136x1.75 track....might even go one step higher...
Jeremy
So by moving the secondary are you gaining more speed or more bottom end punch ???
bottom end....
Jeremy
I know a little bit about clutches, so can you explain how you acheive more bottom end ???
terret725
it keeps the secondary from opening longer. this keeps the sled in a lower gear for longer and makes it back shift faster when u let off the gas. its kinda like droping a gear in ur stick shift car when u wanna pass some one quicker.
Jeremy
Thank you for explaining that for me !!! Merry x-mas terret725 !!!
ya what terret725
said....
said....
08PhazerRTX
does anyone have pictures or a diagram to show how to do this ? is it that hard? do you need to know alot about clutchs or need any special tools ?
Thanks Peter !
Thanks Peter !
http://www.ty4stroke.com/viewtopic.php?t=35515&start=45
8th topic down is pics in one.
Is this using Ulmers spring or the stock one?
