Bodacious
Had the panels off and the clutch gaurd removed last night. Started the engine on the Attak spinning the transmission on the jack stand. Just wanted to see if I could find out where a vibration is comming from at around 60 mph. I noticed that the inner half of the secondary is out of true by an 1/8" it wobbles under way. The outer looks fine. Just wondering if others would try this to see if maybe I have a bad one or is it not abnormal?.....Thanks
