I was out tearing up the lawn today after I put a new secondary spring and new ramps in. I just put a new belt on too. After a few passes the secondary would not close and it was like starting in third gear. Is this just a freak thing or is this something I need to worry about. When I got back to the garage the belt was sitting one eighth of a inch above the sheaves. I did not take a scotch bite pad to it yet. Will that cause the secondary to stick? I am running the helix at 70 degrees (6-1). I am looking for ideas to prevent this from happening again. I am looking to grass drag it this weekend. By the way it is a 03 rx1er. It seems to be running great except for the secondary.
When I took the secondary apart I remembered to mark it after it was apart ( %$&#%#). I did research and lined up the drill holes. If this could be the problem, please let me know. It is posible I mis read the posting.
