rodehard
- Jul 6, 2007
I have a 2011 Vector with a sensitive kill switch. I need to pull up hard on the switch to get it to start and sometimes it shuts down on the trails. Is there a fix or a disconnect or do I have to buy the entire kill switch/throttle flipper assembly for about $150?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Check out barnofparts.com for a great price on a used, clean assembly.
radianguy
- Jan 1, 2007
Bit late for my advice but you shouldn't be using the kill switch to turn the sled off, use the key. The kill switch is an emergency shut off!
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
And if the sled has EFI the ECU doesn't like it at all when you shut it down with the kill switch. ALWAYS use the key!
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
its worn out/broken at this point, replace it with a new or used one. x2 barnofparts
