set -up
fxr
newmarket ontario
for anyone is interested my set -up for an 2011 se this is for all around trail,lake riding. there is no perfect set-up for changing conditions but this works pretty good. my apex has 153 studs up the middle and cobra head 8 inch carbides up front. it also has polaris oversize wheels. fox front floats set at 70 lb.s limiter strap in the middle. note! there are five holes in the strap and it comes from the factory in the first hole. so the third hole. rear shock 150 to 155 lbs. i weigh about 215 lbs. corners flat and doesn,t push. it would great if ulmer or someone else comes out with some adjustment for the shocks and then you could really dial it in. also id love to try more aggressive skis and carbides with power steering i think you could use just about anything and it will still turn. also i forgot to mention transfer rod set in the middle between standard and max.
