Pushing in corners
<<<<i then bought 6' shaper for the outside and 8' woodies for the middle, re adjusted spring, compression and rebound(GTYR shock) and that cured the push. now it rails at hi speed and the steering is still pretty easy....>>>>
Which way did you go with the spring and damping?
