Share your setup... Let's help out the new owners.
DMCTurbo
Val Caron, Ontario
Canada
2017 Sidewinder XTX LE 137
Let's post our setups to help any new owners coming on board. Keep in simple and on track.
Follow my lead:
Primary Clutch
Ulmer pink spring
Dalton Dtya1s
Secondary Clutch
Dalton black/orange @ 3-3
Dalton 41/35 helix
Gearing
22-41
22-37 next winter
Track
1.25 Ripsaw 2 with 192 1.575 Megabites
1" Ripsaw 1 with 144 1.5 stud boy lake racers next year
Tune
Turbo Dynámics flash bundle
Exhaust/Intake
Turbo Dynámics Super Quiet
Turbo Dynámics CAI
Skis
C&A TRX with woodys 6" slim jims
Top speed to date
131.4 GPS
Primary
Dalton Black Teal
Dalton DTYA-1s empty
Secondary
Dalton Black/Orange 70º
TD rollers
Stock helix (may experiment next year)
I have belt dust but original belt still good.
265mm C-C
62.5 offset
NOT machining, still have washer on.
Want to try 41/35 helix
Stock gearing
no plan to change
Ice Cobra 1.6 - zero wear 1300 miles
Changeds slides both seasons NOW have Dupont's
TD stock muffler tunes with flasher and logger
Have only run Eco Trail stock muffler yet
I plant to run Max Stock muffler next year (16 PSI)
115 MPH with more to go. (was 106 MPH before tune)
'17 Viper MTX skis with Semi aggressive snow trackers (ZERO need for power steering). Probably switching to C&A Pro Crossover skis next year. The Tuners are going to hang in my rec room.
Removed transfer blocks
Pulled limiter strap to middle hole (2 shorter and 2 longer available)
Factory oil tank plumbing- no issues.
I have thunder product secondary 33/35, spring and rollers. Curve skis with slim jims and pulled limiter strap in two holes from stock. 144 up the middle. 1800 miles with original belt.
tuners with Snowtrackers
144 1.5 Powerpoints
tunnel protectors
Yamaha rear axle wheel kit
ice scratchers
mid Viper windshield
medium tunnel bag
removed transfer blocks
linq gas can up north mount
rest stock
192 kph.
5000 klms on original belt .
6500 klms. on original sliders.
I love those type of threads ;)!
This is the setup i rode the most last year
Belt ; Ultimax XS-825
Belt guard+ frogzkin
Primary Clutch
Y-w-Y+2 glide washer
Weight Gforce S2
Secondary Clutch
Dalton black/orange @ 70*
Gforce 41/37
TD roller
Spring pocket cut
Gearing
22-41
Top speed 203km/h GPS on snow. Speedo 211km/h
Track
1.25 Ripsaw 2 , light studed 96 1.325 gold digger
4th whel kit,
RR shafts
Dupont slide
Tune
Hurricane flash bundle. Mostly 270
Hurricanne intercooler
Innovate psb-1
Exhaust/Intake
STock modified
CAI K&N
Skis
AC snowtracker agressif or C&A TXR shapper bar 6"
Racewrex rapid block modified
ElKa stage 5
Bellypan protector
Yamaha bumper+ Led bar
Powermadd FUzion handguard
ISOVIBE riser which i realy like
MTN addiction gaz can
I am already on some little mod for next year :)
2018 XTX, just 3 mods for the most part.
Chassis completely stock, no studs, just bigger carbides on skis.
TD Bundle set on PT
SQ muffler
Dalton DTYA1's empty
8DN belt
126 mph on the trail (speedo)
