justinator
Fuel Pressure Test Adapter OST-FST-001 for Mercury, Yamaha, Suzuki
Our fuel pressure test attachment is designed to allow a conventional fuel pressure gauge with Schrader fitting to connect to 4 stroke EFI pressurized fuel systems that have no Schrader fitting but…
outboardst.com
This is what you need to test fuel pressure on yamahas. Good to have for period maint checks if fuel system hasnt been altered in a way that allows easy testing. Disconnect line at rail and ad neccessary ends to the t fitting and this creates a flow through from the pump and then connect fuel pressure tester like what your getting at harbor freight to the T fitting.
justinator
You need to configure in a way that fuel flows through to the rail. If you just add it to top of tank you will get a reading of unregulated pump pressure which will help to diagnose if the pump is bad if it doesnt develop pressure or much of it but will tell you nothing about how the regulator is working. Making it T into the fuel line will show actual fuel system pressure as the engine sees it. Like trail leader mentioned, good idea to remove sending unit when installing pump so you can make sure socks are flat in tank. Ive had one get caught up and not go where it is supposed to and if that happened sled wouldnt run unless you have a tank with quite a bit of fuel in it.I'm just going to buy (if needed) the gauge from harbor freight and then plug it right into the top of the pump.
The gauge from harbor freight has a bleed off to allow fuel to keep moving.
I'm sure I can make something but it's only $32.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Gave this some thought...if my return was routed to deliver fuel to slipper, why would misrouted or bent pick-up tubes be considered as a possible problem?If you can hear the pump working key on, but engine off, I suspect the pickups in the tank or the internal pressure hose to be the culprit.
IDK, just asking.....
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Put stock pump back in and try, quick and easy.
Doc Harley
- Oct 17, 2016
- Here & there
For those of you paying attention, pulling the return line to check for fuel pressure is not the answer. As it pressurizes the regulator and fuel rail, but does not return anything back to the slipper. If I'm wrong please correct me.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Needs to be running Doc for it to flow back to the tank.
Doc Harley
- Oct 17, 2016
- Here & there
So I pulled the line off the top of the pump. Fuel pump engages with key, fuel coming out, then stops after 3 seconds or so. Very similar to the pressurizing of the rail process.
Should I continue with pulling the pump?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
that shows you pump is turning on but you still dont know pressure from pump, do you have the adjustable regulator off the end of rail? is your return back to slipper? i also had issues with the crows feet plugged and not allowing fuel to be picked up.
DMCTurbo
- Nov 12, 2005
Here's how I think... knowing I recently changed the pump and now my sled is acting up I'd be reversing what I did to see if my problem goes away. Maybe there's a better way but that's what I would do.So I pulled the line off the top of the pump. Fuel pump engages with key, fuel coming out, then stops after 3 seconds or so. Very similar to the pressurizing of the rail process.
Then if problem remains you can move on knowing for sure it isn't your pump.
rev them up
- Apr 3, 2006
Keep it simple, put stock pump back in, check all lines, filters, etc when doing so. Start chasing your tail real easy.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
SD26 is a boost leak IMO. I do not believe its related to your idle/fuel issue. How old is the "sock" filter on your pump? Also the filters on the end of the Y that extends forward off the pump. .. I like to replace the sock filter (on bottom of pump)every other year or so.. You guys noticing what the sock looks like after using Boostane??? Not saying to not use Boostane but wondering if it effects the "sock" filter off the bottom of fuel pump.
Doc Harley
- Oct 17, 2016
- Here & there
I sure am glad I tested a few miles from the house. Could you imagine this have been in 0° temps and having to try to do this outside. Sorry guys, my bad...
sideshowBob
Was the fuel line off when you opened it up?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
If you decide to go with a rubber submersible fuel line instead of the plastic , be careful how you route it.. Make sure it does not have a kink or pinch anywhere in it.. I have the plastic on my 2022 no issues what so ever.. Wondering if you heated the plastic to much when installing ?
DooZ
Just spitballing, did you add a fuel filter?
And who is this Doc Harley, what did he do with JT lol
