Vmaxkid
- Oct 16, 2003
- Maine
- 2018 Sidewinder LTX-SE, 2019 Ski-Doo 900T Enduro (not as fun as Sidewinder)
Anyone else have this problem? I took a look under my sled and I see the plastic body side panels melting into the groves of the side heat exchangers.
LazyBastard
It shouldn't even be touching.
Vmaxkid
- Oct 16, 2003
- Maine
It is touching on both sides. The plastic is melting right into the grooves on the heat exchangers.
Tom-RX1
not on mine Sounds a bit strange 220 *f or 100 c will not melt plastic . Any higher than that your system boils over .
Tom-RX1
Tom-RX1
LazyBastard
Actually Tom, NO.
#1) The boiling temperature of water @ STP is 100 C, BUT, if you go outside of STP, the boiling temperature changes. The system is sealed under pressure. This RAISES the boiling temperature.
#2) The boiling point of water is not the same as the boiling point of antifreeze mixed with water. Mixing antifreeze with water RAISES the boiling temperature.
What this means; It actually WOULD take more heat than 100 C to boil over your system.
Tom-RX1
LazyBastard said:Actually Tom, NO.
ou are corect LB but still should not be enofe to melt plastic
Tom-RX1
