viktorpe
- Dec 13, 2021
- Piteå
- Sweden
- Yamaha apex -07
Polaris vr1 -21
Polaris 120 -20
Hello, i have some questions about arp or oem headbolts.
I read that oem headbolts is the weakest point, doesent hold up for power above 330-350hp, anyone with experience?
Is the sidewinder block stiff enough for arp bolts?
I know that some alu block (bmw) doesent hold up for the extra torque with arp, they get oval, hexagone or cracks,
I Have a 2022 with mcx stage 3(19t) raceheader, bigger fuelpump and my plan now is to put dual oem head gasket(0.8mm x2) to get from 9:1 to ~8,3:1 to handle maybe 330-350hp with 91 pumpfuel (sweden 98okt) if possible without knock…
Maybe there is some better choise of thicker headgasket insted of dual?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I run a .035" headgasket which lowers compression to allow more boost on pump gas and also run ARP headstuds torqued to 65 ft/lbs.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
arp studs ...no question... commetic gasket, just be carful on the one stud needs to be cut.
DMCTurbo
- Nov 12, 2005
It doesn't need to be cut. You just need to back it out so many turns... I can't remember how many but it's likely in my Stage 6 build thread.arp studs ...no question... commetic gasket, just be carful on the one stud needs to be cut.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i had mine cut ... just in case when torqing nuts .... the stud could turn in.... just a precaution.
kinger
Double check but I think the new ARP kits include the shorter bolt for that waterpump side. If you do go ARP make sure to follow their TQ spec EXACTLY... do NOT follow the OEM yamaha procedure.
viktorpe
- Dec 13, 2021
- Piteå
- Sweden
- Yamaha apex -07
Polaris vr1 -21
Polaris 120 -20
Okey, do you need to re-torque after startup with arp bolts and Turbo dynamics headgasket 0.052” ?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
no
Turboflash
- Mar 18, 2019
- Southern MN
If you buy the 998 ARP stud kit, that one stud is already shorter. I Loctited mine to make sure they didn't back out next time I remove nuts taking head off.Double check but I think the new ARP kits include the shorter bolt for that waterpump side. If you do go ARP make sure to follow their TQ spec EXACTLY... do NOT follow the OEM yamaha procedure.
No, they don't need to be re-torqued.
Install I used was 3 steps - 12 - 30 - 65 ft.lbs.
They must not cause issues for the 998 block cuz mine have been in since day one and I've had head off a couple times and all is well. Running up to 28-30 psi boost with waste gate shimmed to .030.
NYTurbo
I would re torque if your running high boost. ALso use a accurate torque wrench , , ive heard of block threads being pulled.
Turboflash
- Mar 18, 2019
- Southern MN
Yup. Snap-On.
Did you swap out head gasket aswell or just the bolts?If you buy the 998 ARP stud kit, that one stud is already shorter. I Loctited mine to make sure they didn't back out next time I remove nuts taking head off.
Turboflash
- Mar 18, 2019
- Southern MN
I used stock head gasket and it's fine but of course there are some out there that are supposed to be "upgrades." Either they leak or they don't. If they don't then no need for an "upgrade."
Awesome, I know in the day we just swapped out the bolts and did not change the o.e. head gasket. Is this what you did or did you pull head and install new o.e. gasket & bolts.I used stock head gasket and it's fine but of course there are some out there that are supposed to be "upgrades." Either they leak or they don't. If they don't then no need for an "upgrade."
Thanks!!!!
Turboflash
- Mar 18, 2019
- Southern MN
I had head off so I put in new gasket along with the ARP head studs.
