sinjin
vice108 said:For install - do you use the rubber pieces from the Yamaha spindles or does the mount kit come with different ones?
You use the stock rubber bumpers. I would suggest shimming and Simmons skis work best with no toe in or out - just straight. You will love the skis compared to the stock POS.
vice108
sinjin said:vice108 said:For install - do you use the rubber pieces from the Yamaha spindles or does the mount kit come with different ones?
Thats perfect - I can just leave the Bergstrom shims that I already have attached already. Thanks for the info.
CT4Stroke
Who did you order your skis from?
$380 sounds like a good price with mounts and carbides. I've been thinking about a pair for my 06 Attack. Where did you order from?
Mike -
Mike -
vice108 said:Well - they are on the way. $380 to my door with 6" carbides and mounts.
mikeb
The outside carbide of the ski towards the direction of turn cuts. Each turn has one inside and one outside cabide cutting.
vice108
Re: Who did you order your skis from?
I sent you a PM
CT4Stroke said:$380 sounds like a good price with mounts and carbides. I've been thinking about a pair for my 06 Attack. Where did you order from?
Mike -
I sent you a PM
