Simons CPR installation guide
micke_o86
Northern Sweden
Hello
I have bought a used simons CPR Stage II kit to my 2003 RX1 with 2560 turbo. I cant get in touch with jeff, the website simonscpr.com does not seem to be up....
Does anyone have a installationsguide?
Thanks Micke
when I bought my kit new it did not come with any instructions, had to figure it out on my own.
Hmm alright, i have sent them a mail so lets se if they answer.....
Where should i go with the oil return line from the turbo?
Thanks Micke
I know on my apex it went to the fill plug on top of the valve cover plug. there was a fitting i put in there
If you're still having trouble getting ahold of Jeff send me a PM with your mailing address and I'll ship you an installation video.
*Note that the vid is only on VHS
Hmm alright, the email adress ive got to Jeff does not work....
"lakercr" you got PM.
Any other suggestions on the return line?
Thanks Micke
the return was designed to go into the valve cover, alot of people moved it down to the top of the cover behind the primary clutch, but this takes some modificatios to the cover, you will need to insatll a nipple on it, or just route it into the top of the valve cover just in front of the turbo. just remove the plug and the kit should have come with the fitting to screw into the valve cover.
^^^Good advice ^^^
Micke, I replied to your PM. If you understand the general idea of installing the parts I can probably post pictures/instructions of whatever you get hung up on. Otherwise (and as I said in my PM), I can ship you the VHS tape if you give me your address. You might want to confirm first if it will play on a european machine though.
Alright, does it not work good with the return in the valve cover when people moves it? "La kercr" i will try some more but if i dont make it i will contact you!
So does anyone know what happened to Simons CPR, I thought he had a tech section on this site and it's gone along with his website, email etc. What's the scoop here? I noticed that several people here are trying to get a hold of him with no luck, Jim?
Well I was wondering about this as well so I called Jeff on Saturday. I didn't have any trouble getting through to him - he answered on the second ring. CPR hasn't gone anywhere.
I mentioned to him that his domain needs to be renewed and he was going to look into it. If any CPR customers have a specific concern I'd encourage you to call Jeff yourself and discuss it with him.
Hello
i have some questions. Where do i place the the fuelpump and fuelpressureregulator? any pictures?
Thanks Micke
