birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Have any of you tried to run a single pipe on a Vector, Phazer style? Or single pipe under tunnel?
Would like to try out a Phazer style exhaust on the Vector, under the seat
Looks very motocross-ish
Just been to a moto-x race, and man those 250 and 450 4-strokes sounds cool!!
06vectorgt
birkebeiner said:Have any of you tried to run a single pipe on a Vector, Phazer style? Or single pipe under tunnel?
Would like to try out a Phazer style exhaust on the Vector, under the seatLooks very motocross-ish
I do have Aaron's header on my Vector but not the 3 to 1 system, check out his video;
http://www.excellmotorsports.com/video/ ... em_wmv.htm
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Any noticeable difference with the Excell header over stock?
06vectorgt
birkebeiner said:Any noticeable difference with the Excell header over stock?
birkebeiner
I did the clutch kit and carb springs at the same time so it was tough to tell just how much the header did all by itself.
I will tell ya that my buddies 03 F7 (the fastest year) has a hard time pulling me in a drag race. The only reason I did not do the three into one is that it only provides 1 extra HP more - the header alone = 6HP (per Aaron Excell). You can't beat the sound but noise restrictions are getting pretty tight around here and I don't need or want the hassle.
Hope I helped.
Lou
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks buddy!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
06vectorgt said:I did the clutch kit and carb springs at the same time so it was tough to tell just how much the header did all by itself.
Lou
Is the clutch kit from Ulmer Racing? Stage 2? And where did you get the carb springs from? What do the carb springs do btw?
Thanks again buddy
06vectorgt
birkebeiner said:06vectorgt said:I did the clutch kit and carb springs at the same time so it was tough to tell just how much the header did all by itself.
Lou
Thanks again buddy![]()
Clutch kit from Pioneer Performance
http://www.pioneerperformance.net/
Carb springs from Holtzman Engineering;
http://www.holtzmaneng.com/
Look under - CV Carb Slide Springs (green for me)
Your welcome!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
06vectorgt said:Clutch kit from Pioneer Performance
Your welcome!![]()
How is the Pioneer Performance clutch kit compared to Ulmer Racing stage 2?? Anyone knows?
Thanks again!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Do I have to change any carb setup when going with the Excell header/Ulmer clutch kit/Holtzman carb springs/CK10EK spark plugs upgrade??
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Do I have to change the carb jettings when upgrading to Excell header, Ulmer clutch kit, Holtzman carb springs and CR10EK spark plugs?
