maddog63
- Aug 8, 2008
TTT - I'm new on here and primarily a Skidoo guy (dont be too hard on me!) My dad has an 08 Nytro, and I gave him a pair of pilot skis which we are tying to mount on.
looks like I have to get either the Doo ZX rubbers or the Slydog mount kit. Sounds like the Slydog kit will fit a little better, but which kit? Their site has mount kits form about 10 makes. Would it be the ZX mount kit or the Nytro mount kit. On the site they cost about $27. Is that right or do I not need the entire mount kit ( or just the rubber). Should I get the kit right from Slydog or are there any good site sponsors you recommend?
Also the stock spacer on the Yami spindle is too wide and it is a super tight fit to put the Pilot ski on. Has anyone grinded that spacer down about a 1/4" or so for better fit?
Thanks in advance for all the Yammi help!
berge75
You don't need the kit from slydog,just the rubbers. As far as the bushings,you need to have one bushing to the inside and one to the outside. Just run the stock bolt thru with the washers,and u should be good. I have the 6.9s with Shapers, on my XTX and with the hygear set up the sled handles awsome.
rhoag
Just push out one of the bushings in the ski and move it from the inside to the outside or both and use stainless washers on the inside.maddog63 said:TTT -). Also the stock spacer on the Yami spindle is too wide and it is a super tight fit to put the Pilot ski on. Has anyone grinded that spacer down about a 1/4" or so for better fit?
uofm
kits
call slydog @ 866-759-3647, part #04-b004-2. just ask for the rubbers, they are $5 a piece.
