ski lift; wheely?
andrewizme
vermont
Any tips on how i can get my 05' vector to come off the ground? My skidoo buddy has it in his mind that its too heavy in the front, what mods will make me lift up?
I could stand mine straight up with no studs.
Tighten your center shock and adjust your transfer nuts all the way so you get max weight transfer and sit back.
Mine would stand up like crazy. Loosen limiter straps all the way, put blocks on soft and loosen trandfer nuts all the way back. It works!
transfer straps can be bought from mountain performance. Then it will be the ultimate wheelie monster.
CAUTION, dont do this with studs and hard packed riding. It is very hard on track clips, rails and drivers!
Same goes with loosing the rear transfer rods and tightening the front shock. When you transfer you will be loosening the track and you will ratchet. Damage will be track clips and/or drivers. IMO! (this is if you go to the extreme!)
