twomorestrokes
PJVMAX said:Are these spring settings 1/4" softer from the stock setting (middle of range) or from where your sled was set from the dealer setup? All spring settings on my sled were full soft from the dealer. What is your weight?
From reading my shop manual, it looks like the dealer left them at factory settings. I know they didn't do anything special for me, as it was a floor model and they never asked me anything about my weight or riding style. I'm 225 and ride fairly aggressively.
PJVMAX
twomorestrokes said:PJVMAX said:Are these spring settings 1/4" softer from the stock setting (middle of range) or from where your sled was set from the dealer setup? All spring settings on my sled were full soft from the dealer. What is your weight?
Thanks. You're about 30# heavier than me. I reset the springs to stock settings on my sled from full soft, sounds like I might have to soften them up a bit. I have the limiters pulled in one hole (I like a little more ski pressure than most) and the anti bottoming stopper on soft (based on comments here about too much rebound). I really need to ride this sled!!
twomorestrokes
I think these settings basically get the front a little lower and limit the transfer a little bit. From what I learned from another member, the 1/4" less preload on the center shock is to work better with the shortened limiter strap. Made sense to me. I set my torsion spring setting to firm due to my weight and riding style.
I also have the snubbers moved to the front hole and that was a huge improvement on bottom outs as far as my spine's well being goes.
PJVMAX
Thanks. I'm trying to get a starting point close to what I think I will need based on what I've read here. Like i said, I really need to ride!!
