Guys, all I have ever done is just replace the carbdes. I see were guys are shimming to reduce darting and pushing in the corners. Are shims the same thing as ski savers? If soneone could explain I would be grateful. Thanks
Tork
shims and savers are 2 different things. shims go on the back part of the rubber bumper that surrounds the bolt that holds your ski onto the spindle.
savers are a shim too but they go between your carbide and the ski
Ok thanks for that explaination. I understand what the savers do. Now could you explain what the shims do on the rubber bumper.
Thanks Tork
Thanks Tork
Tork
We have great info on that.
Under the add banner above, 5th line down you will see TY tech, click on that, navagate thru to 2 articles, Darting and one on Shimming
Thanks Trok.
