powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
powderlites
- Sep 5, 2005
powderlites
- Sep 5, 2005
type809
I'm hoping all would agree in the future it might be helpful that when posting maps you could include elevation, decomp. or not, injector size, fuel pressure, safe fuel type for boost @ elevation, and maybe even turbo. This would make it easier to compare these maps and see if they would work for any given application.
For example:
I want to take my sled up to 9000 ft, and know that I can only get 87oct. My sea level map won't work, so I look here to see who has a map running a 1:1 fuel regulator set at a 58psi base with 725cc injectors, with decomp motor safe for 87 @ say 12lbs.
as in my map which seems to work well for me, is quite different than the other maps on this board.
thanks
thanks for the update: this really does help!
For example:
thanks
groundman
- May 28, 2011
hey guys,
anyone have a PL low boost sea level map they dont mind sharing? machine has 700cc injectors,3bar map sensor stock compression, stock fuel system, 6-7psi
thanks for any info
thanks for any info
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Dave,
Any maps for stock (non-turbo) 1200 with Header and Hindle can?
- 6K
