BlueBlood
That's what I was going to say Mighty--you beat me to it. The hardware bag was supposed to be used. You can't just replace the rivets, the parts are included with the plate.
Starry Knight
I was planning on using my oil pump (which pumps out of the dip stick tube) to change the oil in mine.
Does anybody know if the oil filter can be used for a few oil changes?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yamaha says to change the filter at 500 miles then you can let it go to about 12k or seasonally. I always change the oil filter, this may be the exception. This engine operates in a very clean environment.Starry Knight said:I was planning on using my oil pump (which pumps out of the dip stick tube) to change the oil in mine.
Attak
Mighty,
I assume you ment 1,200 not 12,000?
Chris
Chris
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Nope, 12,000. Like I said, the engine runs in a very clean environment. I will however replace it seasonally (if I keep the sled that long lol).
Attak
WOW! Thats amazing.
I am new to four stroke sleds and don't want to start a big oil debate. I normally run Mobil 1 in everything including my dirt bike and boats. Will I be able to run it in my Attak or do they require something special?
Chris
Chris
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I too run synthetic, Amsoil. I usually wait for the engine to get a few thousand miles on it first.
I ran amsoil 0w-40 in both my RX-1 and Warrior and will run it in my Attak.
Nice Rumble
MightyWarrior said:Why?? To hold them accountable.1CrazySledder said:Maybe it's me, but why take a sled back to a place that screws it up the first time around.
Vince
Accountable? That may very well be however be prepared for a $60.00 bill for something you could easily do yourself and know it was done right. You also learn about your machine as well. What a rip off!
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
First off they wouldn't get a nickle from me. I myself would have done it myself, but that's beside the point in this case. They screwed it up, so they would fix it if it was mine.Nice Rumble said:Accountable? That may very well be however be prepared for a $60.00 bill for something you could easily do yourself and know it was done right. You also learn about your machine as well. What a rip off!
Everybody.........Yes, I plan on doing some MAJOR B!TCHING. Besides, they were the ones who screwed up the skid plate - they should fix it. By the way, I generally do all the maintenance on my sleds myself. The only reason for bringing the sled back is to make the dealer correct their f'up.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
WFO said:Everybody.........Yes, I plan on doing some MAJOR B!TCHING. Besides, they were the ones who screwed up the skid plate - they should fix it. By the way, I generally do all the maintenance on my sleds myself. The only reason for bringing the sled back is to make the dealer correct their f'up.
I hear ya. Hope you get it taken care of.
VINCE
