Skinz Airframe running boards.
Furgwa
Weyburn, Saskatchewan, Canada
Is there such a thing for the XTX? All i can find is the MTX kits. Or do the MTX boards fit the XTX? I've been scrambling trying to find some info, but have not found anything conclusive... Anybody running them? :Rockon:
I suspect that The boards themselves will work fine as long as you order the ones for the 2010 mtx, as this should be the same tunnel as the xtx. Only with a different tail. Where you problem will be is with the drop brackets since the xtx suspension mounts in a different place than the mtx.
Ok, do the boards mount to that bracket? Is that where the problem is? I e-mailed Skinz also, hopefully they get back to me. They look awesome, hope I can figure something out with them.
