gabe7924
I also hear you can make a good exhaust out of a few soup cans and some fiberglass insulation . Maybe you ought to try that out too! Try chili cans for even more horsepower.
ptrudel
way to be mature
i'm not tryin to get into a pissing match with you here...i was just stating the obvious...looks exactly the same, but coated black...hopefully it hold up for ya though
rfabro
Sounds like a lot of bang for your buck, gabe. Let us know if tunnel packs survive. If no ploblem, then that muffler is the bomb
gabe7924
I wear my pack on my back, but after riding all day today and last night, I am sure you can put a pack on the tunnel with no problem. It is a great sounding exhaust that packs a good punch.
jp@weknowsnow
- Jul 19, 2006
- colorado mountains
- weknowsnow.com
thanks for the info gabe. can you post a pic? does the exhaust turn down into the tunnel? i'm gonna order one asap if it will clear up the exhaust issue off the back! thanks!!
gabe7924
It turns out to the left side of the sled. I would say no problem with the pack.
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
thanks just ordered one.
gabe7924
If you look at the black one above, you can see the turned tailpipe. You are looking at the bottom of it in the pic. It uses stock mounting hardware and even the stock black plastic piece bolts right to it.
JP and Gabe, where did you guys order from?
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
Phazed-Coug said:this is all I could find...
http://www.tufpowersports.com/eshopprod ... E_SILE.htm
i ordered it from here...
SILENCER ULTRA-Q YAMAHA
#1841-0050
nice find gabe.. going to build a rad guard tomorrow.
gabe7924
Any shop that is a Parts Unlimited dealer can order it. Use Parts Unlimited part #1841-0050
Thanks.
So I'm assuming that snow isn't needed to cool this exhaust. Which means if I get get it, I can close my tunnel off.
How noticeable are the power gains? Like is it definitely noticeable, or does it just 'seem' like it pulls harder?
Closed tunnel, less weight, more power, and better sound. I think I may have to get it...
gabe7924
It probably still needs to be cooled like the stock one. I'm keeping my tunnel open. It just pulls a little harder. It's not an incredible gain or anything like that. I am also riding at 11000 feet and up. I need every extra bit of power I can get. The gains may be much more noticeable at lower altitude. For me, it sounds a lot better and is much more responsive on the throttle. Better out of the corners. Good ,crisp throttle response is what I noticed most.
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
gabe7924 said:It probably still needs to be cooled like the stock one. I'm keeping my tunnel open. It just pulls a little harder. It's not an incredible gain or anything like that. I am also riding at 11000 feet and up. I need every extra bit of power I can get. The gains may be much more noticeable at lower altitude. For me, it sounds a lot better and is much more responsive on the throttle. Better out of the corners. Good ,crisp throttle response is what I noticed most.
gabe you should come out and ride with us! bring your snowboard
gabe7924
JP, I would love to come your way sometime soon. I will be busy with XGames in Aspen for the next few weeks. Let me know if you are coming over here anytime.
