rfabro
gabe, jp where in CO are you? I lived in Vail 13 years(92-05). I'm gonna roll down a few times in spring and, if the snow lasts, a time or two in summer. With the the way things are going, you guys will be sledding into July, no problem!
gabe7924
Rfabro, I am in Aspen. Let me know if you ever get this way. The riding is excellent right now. Bottomless powder.
jp@weknowsnow
- Jul 19, 2006
- colorado mountains
- weknowsnow.com
i'm around the front range and northern colorado often. gabe we gotta do a sled trip around the back side of purgatory
rfabro
I left CO before last winter and you guys are having the two best winters ever. I think about coming back a lot
gabe7924 said:It probably still needs to be cooled like the stock one. I'm keeping my tunnel open. It just pulls a little harder. It's not an incredible gain or anything like that. I am also riding at 11000 feet and up. I need every extra bit of power I can get. The gains may be much more noticeable at lower altitude. For me, it sounds a lot better and is much more responsive on the throttle. Better out of the corners. Good ,crisp throttle response is what I noticed most.
I'm in MI, so I'm at a much lower altitude than you. Maybe I'll get some more out of it.
About the cooling of the exhaust, I might try to contact Skinz to find out if it really does need to be cooled. If it doesn't, I'd really like to close my tunnel completely.
gabe7924
They seem prettty knowledgable and friendly on the phone. I am sure they will steer you the right direction.
Phazed-Coug
jp@weknowsnow said:i'm around the front range and northern colorado often. gabe we gotta do a sled trip around the back side of purgatory
Let me know if your coming down to Purg, to ride... I don't know the area super well, but I've been up there a couple times and would definitely go again.
redrocker07
Why is the tip bent instead of shooting straight out the back?
gabe7924
redrock, so you can put a pack on the tunnel and not melt it.
donnyrhodes
- Nov 12, 2006
so how does this sound?????????
gabe7924
sounds great
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
mine is on the way. i'll post up some pics after the install.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Did you have to cut your stock system or was this a direct bolt up system?
gabe7924
They give you a template to cut your stock pipe off. Then it slips on and bolts right up. Stock mountas and everything.
GypsyRoots
- Oct 29, 2006
