myrodman
- Feb 26, 2008
- NEW BOSTON.ILLINOIS
- 06 attak
05 warrior
I have a 06 attak with Yamaha tuner skis running 6 in carbides on the outside and 4 in on the inside The sled darts really bad I checked the toe and it's set at about 5/16 toe out Is this toe setting correct or does anyone have any other ideas? thanks
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
snow trackers
slowride06er
Is the sled studded? Did set your sit in, measure spring before you sit on sled and have a friend measure while you sit on sled. Think man calls out for 40mm to 50mm difference. What were conditions? What is your transfer at? I run my transfer at max while slow trail cruising riding but when I ride with a different group I set transfer to min for more of a gas and go riding style. When transfer is at min you corner flatter and faster but sled will dart somewhat more setup like this. I have beg triple pts on my sled its extended to a 136 with a ice ripper track. For me if darting gets bad I increase the transfer its all comes down to personal preference. Are your skis shimmed to lay flat?
myrodman
- Feb 26, 2008
- 06 attak
05 warrior
The sled is studded and I did not set in it while measuring the toe It darts at pretty much all conditions I have never checked transfer but can look in the manual to do this Can I ask what you mean by shimming the front skis to lay flat? ThanksIs the sled studded? Did set your sit in, measure spring before you sit on sled and have a friend measure while you sit on sled. Think man calls out for 40mm to 50mm difference. What were conditions? What is your transfer at? I run my transfer at max while slow trail cruising riding but when I ride with a different group I set transfer to min for more of a gas and go riding style. When transfer is at min you corner flatter and faster but sled will dart somewhat more setup like this. I have beg triple pts on my sled its extended to a 136 with a ice ripper track. For me if darting gets bad I increase the transfer its all comes down to personal preference. Are your skis shimmed to lay flat?
34pontiac
Snow trackers.. 0 toe in/toe out and be done..
They have been making them for tuner skis now.
slowride06er
There is a link in the freq/asked with pictures it doesn't take long to do. If you need more help I can post a link on Thursday. I'm out of town away from computer. Phone is smart butThe sled is studded and I did not set in it while measuring the toe It darts at pretty much all conditions I have never checked transfer but can look in the manual to do this Can I ask what you mean by shimming the front skis to lay flat? Thanks
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
X2snow trackers
Snow trackers eliminated 100% of my darting.
UP Michigan rider
This article is worth a read at least. "Some riders who bought these skis started out with way too much carbide, or way too aggressive in their runner combination selection." https://www.snowtechmagazine.com/yamaha-dual-keel-dual-runner-skis/
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
If you shim and align your ski's and they still Dart . Check your front end bushings by getting the front of the sled off the ground and grabbing the upper "A" arm back by the bulk head . If there is movement the bushings are shot and should be replaced.
Winderallday!
Different year Apex here, but first year with tuners for me, running 6+4 with zero toe, no darting or hunting, so far impressed.
As mentioned above, check for loose bushings in A-arms and spindles.
When setting toe, make sure you bungee the skis at the front to account for any toe-in slack, and when checking toe, sled should be on the ground not in the air.
Cheers.
Cheers.
Darren Betker
Ditto. Got em on pilot skis and have gotten rid of 95% of darting. Love it.snow trackers
