Well, I tried my old 2 wheel sled dolly (the type with wheelbarrow tires) on the new Attak and it won't even lift the sled to the top of the suspension. Tried a buddy's newer one and it only lifts the sled about 1" off the ground. Who makes one that will lift the sled and give me at least 4" of clearance to push the sled into the shop across the gravel and snow?
It is funny that you are writing this.
I just had the same problem today moving my apex.
I am going to look for larger diameter wheeels.
if i can not find larger dia wheels i will cut off the wheel supports and re weld them lower on the frame so i can lift my apex.
There has to be a cheaper fix then spending another 200+ on a new lift i only use 4-5 times a year
