sledsearcher
My HId lights (sled start) started to become possessed tonight. One would go out then both then both back on, etc. I have had them for 3 seasons and this is the first time I experienced this. Any thoughts on where to start investigating? I assume there is a bad connection somewhere but was hoping for some guidance. FYI it's a 2009 xtx
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
Do you have xenon lights, or HID lights? I have DDM Tuning HID's, and last year, mine would go on and off, then the fuse to the battery connection popped. I changed the fuse, haven't had a problem since.
sledsearcher
Sorry, HIDs from sled start.Bahr05 said:Do you have xenon lights, or HID lights? I have DDM Tuning HID's, and last year, mine would go on and off, then the fuse to the battery connection popped. I changed the fuse, haven't had a problem since.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I have one bulb that only works when it wants too. Same thing sled start hids
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Are your SledStart HID's the older version with the wire connected to your battery? Maybe a loose battery connection? Just a thought.
I bet you have those crappy patch cables... those things are a joke. I ripped them off and wired them direct or talk to Rockmeister, he can get you the correct ones that work.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Could be a weak or dying battery, causing a misfire of the ballasts. I had this problem on my Nytro. Needless to say, I never installed them on my Apex.
Do you have any other electrical items mounted on your sled that may draw some power from the battery, ie. temg gage, gps, etc.?
sledsearcher
I have no other electrical items/accessories. My battery isn't giving any indication of being weak. Hmm
sledsearcher said:I have no other electrical items/accessories. My battery isn't giving any indication of being weak. Hmm
Remove the patch cables and wire them direct with the other harness that came in the box originally.
rage man
bad ground
