gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
2007 rtx apex sc ,
added slydog skiis this year pushes crazy , any ideas ???
next move is to pull limiters !!!!!
TrailxRider
I don't have slydogs but I read on hear somewhere of someone else having a similar problem and a few guys said to check and make sure you have the proper toe in-out set up.
Grimm
True, they perform best when toed in 1/4", however Slydogs aren't all that aggressive of a ski. You need to be an aggressive rider to get these to work for you. Pulling up on the limiters should help, as would reducing center shock pressure.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
I have mine toed in with isx inch shaper bars, work great for my fx nytro
studdog
Great ski' I've rin the, on three sleds. 2 Apex Attaks and 09 Venture GT. Your pushing has Zero to do with the skis. As long as they are square or toed in slightly. You may need more pressure on the skis. Limiter in one hole perhaps?
greenmntpass
Pushing is the last thing I'd worry about with my Slydogs. What do you use for a carbide? I use a 7.5" shaper bar with zero push on an '06 RTX, with limiter strap at stock.
NJNYTRO
I really don't think its the skis. I've got them on my nytro and they did great but its a combo of things. Like others have said, limiter strap is key and make sure they are aligned to straight to a 1/4 in. Also make sure they are shimmed correctly. What shocks are you running and what sway bar do you have. I changed all at once and just fine tuned.
gsxr
- Feb 24, 2006
- 2023 SRX
13MMsway bar and Fox evol x ft shocks.
NJNYTRO
what pressure on the fox? I run about 40psi, a-rms are almost level. changes the ride alot for me- try it.
