Apex18
I just got back from a ride, put my sled on the stand, started spinning my track, head this clunkin noise, looked down and theres my transfer rod snapped in half, with a big piece of it rubbing against my track, which wore down to the steel track crossthreads every 2 inches all the way down the track. So i'm not happy. I had it set to max, so now i'd say you shouldn't do it. So does anyone run without the transfer rod? I know there is a few guys out there that broke them, and i'm not spending 500 bucks on a new one. I know your skiis will be up alot, but it probably wont be much different then when the rod was set to Max. Can you do any damage with not having it in there?...like is there anyway to over extended your suspension or something? Thanks everyone. I'll take a picture of the damage tomorrow when its not dark out.
Jord
Jord
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
cant run without it unless you want more damage...there's a few guys parting out machines in the classifieds...used is about half..but if an of your pars are good you might be able to buy the broken parts to fix..
apltx08
As "sj" said I wouldn't either try this guy he's got a lot of parts at a reasonable $$$
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It won't hurt a thing to run without it. Got a friend with over 2000 miles without it. Nice soft ride if you like the skis up on acceleration.
boone
transfer rod
Yes you can run without the rod I have for over 2000mi, but the rear of the suspension can reverse and get stuck you then have to pry it lose. So I put a set of old polairs blocks in that stop it from getting stuck.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
not only reversing...you will put more stress on the already prone to cracking front arm....and I know someone who did this and stabbed a track window..
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
At least you will not have to hear that god awful clunking noise when going slow over bumps!
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
I looked at Port Yammi and the rod is $52.50 or Extreme Powersports is 48.50 US, So if that is all that is broken. Canadian price would probably be 50% more. Do u have a dealer in Atikokan?
grumpysanta
weld it and get it turned down in a lathe
Apex18
Well i took off the transfer rod today, there is not a single part on there that i can salvage. The rodes bent, and all the other pieces are either missing or scrapped to much to reuse probably from running on the track for 60 miles. What a pain in the butt, i dont have warrenty either. You guys think yamaha would cover a part like this even though i'm off warrenty? Because this should never happen.
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
I doubt it.
apltx08
Its 1 thing I check regulary to see if its loose and make sure the the counter nut is tight and snug...LOCKED so it doesn't become undone.
Apex18
No warrenty, looks like i will have to order a complete new transfer rod. So you guys think i can run without it for the meantime?
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Have u checked with any of the sled salvage yards?
http://www.hud-son.com/sled_shop_slide%20show.htm
http://www.alssnowmobile.com/default.aspx
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Apex18 said:No warrenty, looks like i will have to order a complete new transfer rod. So you guys think i can run without it for the meantime?
in a very calm firm manner...I have gotten an entire crankshaft assembly covered out of warranty calling yamaha customer relations and complaining....it took a few weeks and some persistance...but they covered it...
I bet they would goodwill at least some of it..
