FXMAN
would a 14" wide polaris sno-x track fit on a phazer fx? the polaris track is 121x14x1.75 im am asking cuz i can pick one up for about $100
FXMAN
nobody knows if that extra 1/4 inch will make a difference??
BonelNytro
my guess is it wont, you will have to change out the drivers, this is a pretty deep tunnel and should be enough room but contact your dealer or kevin @ port yamaha
What drivers would you have to change to and why would you have to change drivers? Frank.
terret725
the polaris tracks are 14.75 not 14 as far as i know. and that was on like the 04 05 sleds.
ultimatewarrior
I would think that you would loose a lot on the top end with any track over 1.25.
08NitroRTX
FWI
I run a Polaris 121x1.75x14 (04 track) on my daughters MXZx 550 fan. It has plenty of power to pull it!!! The Phazer will also have plenty of power to pull it! (sorry I can't help with it fitting in your chassis BUT I can't imagine it will not! Both use 2.52 pitch drivers.
