Skid is out, Center float is in, and I'm not sure what I'm going to do with the rear shock. The Phazer sleds run a different shock setup than most other torsion spring sleds. To allow the use of fox float in the rear I would need to make a bracket, add 2 linkage rods, and add a front pivot point for the shock and linkage rods to mount to. All that adds up to enough weight to negate the weight savings of removing the torsion springs. The REAL issue I was trying to solve was the bottoming of the rear arm and I found out why it seems to bottom so easy. The movement of the rear arm actually causes the shock to act like a FALLING rate suspension where it get weaker though out the travel due to the angle of the shock. During the last 2-3" of travel the shock has very little damping effect and you are basically relying 99% on the torsion springs alone to stop the bottoming. I think instead of building a float setup I'm go to try a Fox Zero Pro with 2 stage valving and make or add some sort of spring stiffeners like a few companies sell that bolt to the rails and change the load point of the rear springs during the last few inches of travel to stiffen up the spring. I really don't want to install RTX springs which are 45% stiffer because I like the soft ride the MTX spring provide for small to medium bumps. I'm REALLY looking to improve the big bump action without hindering the stutter bump ability. I know the Float will fix my front arm from bottoming out.
