Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2023 AC T-Cat EPS w/ATAC
- Sledding Location - Fenelon Falls, ON
Thanks - was asking because it states on the product page "A unique EPS shim pad assembly", and if I look up the part numbers for the shims on the S-TX, it's a different one than the regular shim kit. So maybe I'll just order one and see if the kit has one that is higher than what comes on the sled .
kviper
Maybe there is something different then. I thought all of the kits I saw had the same part number but I could be wrong.Thanks - was asking because it states on the product page "A unique EPS shim pad assembly", and if I look up the part numbers for the shims on the S-TX, it's a different one than the regular shim kit. So maybe I'll just order one and see if the kit has one that is higher than what comes on the sled .
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
I believe the '23 tech update says the EPS models come with a 5.0 shim in the rear and a 0 in the front. The non EPS models use two 0's per ski.
I interpret this to mean Yamaha believes with a 5.0 in the rear, steering effort will be greater, but overall the chassis handles better. EPS in this case masks the steering effort so they run the larger shim.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Why would they shim the EPS models any different then the standard model? Not saying your wrong.. Just makes no sense to me, as that's a big shim in the REARI believe the '23 tech update says the EPS models come with a 5.0 shim in the rear and a 0 in the front. The non EPS models use two 0's per ski.
kviper
That makes senWhy would they shim the EPS models any different then the standard model? Not saying your wrong.. Just makes no sense to me, as that's a big shim in the REAR
That makes sense as to why they would do that with eps. Snowtrackers is where the difference comes in.I believe the '23 tech update says the EPS models come with a 5.0 shim in the rear and a 0 in the front. The non EPS models use two 0's per ski.
Derek Fosbury
- Jan 18, 2021
So the shim kit comes with 7.5mm I beleive, so if want more rear ski pressure (non snowtracker carbides ), seems like I should give that a try.
And sorry for straying off-topic a bit
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Maybe start with the smaller shim and work your way up. 7.5 is starting on the maximum thickness.So the shim kit comes with 7.5mm I beleive, so if want more rear ski pressure (non snowtracker carbides ), seems like I should give that a try.
Derek Fosbury
- Jan 18, 2021
I'll wait and see what's already in there, but if it already has the 5mm in, 7.5mm is my only option to try something different, isn't it?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
My ‘23 LTX LE w/EPS came with the 5.0 shims in the back.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes correct. Or go less then 5..I'll wait and see what's already in there, but if it already has the 5mm in, 7.5mm is my only option to try something different, isn't it?
Derek Fosbury
- Jan 18, 2021
Ah, I see, good point. Love learning stuff on this site .Yes correct. Or go less then 5..
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
You could also experiment with a 2.5 in the front too if you’re just looking for something different.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
After terrible darting on my 21 with Stryke skis I bought the semi aggressive snow trackers. While it needs some fine tuning, it went from a darting nightmare to one handed triple digit machine. I still need to play with it but am extremely happy with them.
kviper
I put another 110 mi on my sidewinder with the stryke skis and agressive trackers in a little different conditions. It's not tarable but not as settled as I'm used to with snotrackers. Being I don't have enough snow to test with I put my stock tuners with trackers back on for now.
- 9K
- 7K
