BombaPolaYama
I'm planning on putting snow trackers on my 2010 RS Venture TF and would like some input on whether the aggressive or semi-aggressive would be best? I do mostly two-up trail riding in twisty trails. BTW, besides longer carbides (7.5 vs 6") on the aggressive ones, are there any other differences? In the pic on Yamaha's site looks like the channels may be deeper on the aggressive trackers. I was wondering if the aggressive would be too much on the TF skis which I believe have a deeper keel.
thanks,
thanks,
kviper
I have run them on my sled and my two Phazer's for a few year's now. I would only go aggressive if you do a lot of hard cornering. They both track perfect but the aggressive's will steer a little harder at slow speed's.
Of course maybe you could use the extra bite on the long track?
BombaPolaYama
thanks for the reply.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Go aggressive!
Stephfg
I have the aggressive ones and ride alone most of the time. I haven't tried the semi but I'm sure they'd be quite sufficient. Even the semi are much more aggressive than anything out there.
BombaPolaYama
Thanks.Stephfg said:I have the aggressive ones and ride alone most of the time. I haven't tried the semi but I'm sure they'd be quite sufficient. Even the semi are much more aggressive than anything out there.
musselmark
I will sell you mine, I don't know if it is me or the snow trackers but after I put them on (aggresive) I rolled my venture a few time and I plan on removing them.
rlemotorsports
My wife and I both run aggressively.
BombaPolaYama
Yeah that is a bit worrisome but I read on here that someone else also had tippy problems (on an Apex) but fixed it by adjusting their suspension to looser settings I believe. I know the TF is set-up pretty stiff from the dealer and most people on here readjust it to lower the sled. What venture do you have??musselmark said:I will sell you mine, I don't know if it is me or the snow trackers but after I put them on (aggresive) I rolled my venture a few time and I plan on removing them.
thanks,
