snowtrackers and roll overs
PEI Canada
I installed agressive snow trackers on my '07 venture and it made a huge difference in the handling, huge improvement but I also rolled my sled twice and am thinking it may be because of the trackers, has anyone else experienced this.
I have used SnowTrackers on the last three sleds . Never rolled any of them. It may be that you will need to get used to the increased bite in the corners of the SnowTrackers. They will not push in the corners in hard pack. Alot less steering input is needed to turn.
I have found that minimal ski lift with the Trackers is all you need to take an aggressive corner. Once the sled pitches into the corner and the inside ski is up in the air the trackers will not push or slide out like regular carbides. This positive bite is great but also can lead to one over drive the corners.
Setting the front spring preload to "zero" will help the sled in the corners as well.
That may be the answer, I have my front springs set to the 4th notch, what about the rear transfer arms, any idea where to set them with snow trackers.
I have my mono's set at the factory setting for transfer and max preload on the rear spring.
