Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Well, no better time to start thinking about better sled setups than mid August...
I'm currently running Pilots with 6" shaper bars down the center. This setup works much better than stock but I've read so many good things about snowtrackers that I'm thinking of giving them a go.
- Is anyone using them on their RS Nytro's?
- Should I use them on the Pilots or stock skis?
- Should I go with the semi-aggressive or extremes? I noticed that most Apex riders go with the extremes but the Nytro is a bit lighter in the front.
Cheers!
Brad
Cheers!
Brad
Yeller
I had the semi aggressive snowtrackers on my 07 nytro and they were by far the best upgrade that I put on the sled. No darting and razor sharp cornering. You will not be disappointed if you buy them!
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Thanks rik. I assume you installed them on the stock skis
Brad
Brad
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Where can I buy the snowtrackers? Need them to be shipped to Norway...
06vectorgt
birkebeiner said:Where can I buy the snowtrackers? Need them to be shipped to Norway...
http://www.snowtracker.com/en/about.html
birkebeiner
- Jul 27, 2009
- Norway
- Norway
They do not ship overseas :-(
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
I have been buying them from Royal Distributing. (800)265-2970 (519)822-6903, in Canada. Get them early because i think they ran out last year once news got out. I would also go with the extreme's. kviper
Yeller
Bradford said:Thanks rik. I assume you installed them on the stock skis
Brad
Yes on the stockers.
- 11K
