yamahammar
I'm going to run some snowtrackers this season but i've got a set of pilots and stock skiis and can't decide which ones to use . Has anyone tried snowtrackers on both of these skiis ?
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
Can't comment on Pilot's, but I do have the extreme Snowtrackers on stock ski's after coming off duece bars and they work great, makes the steering so much lighter and no darting or understeer in the corners. Just need to take out ski bumper shims if you have them installed and back off pre load on your front shocks to lower the front end. They look goofy, but do they work!
yamahammar
Thanks for your reply .
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I've got them on both, it makes no difference. they work the same on either. I run them on a 6.9 pilot for better floatation. Other than that no diff.
snowrider RX1ER
- richelieu quebec canada
- www.carrosserieclaudedemers.com
EVERY ONE IN QUEBEC RIDE SNOWTRACKER
THE BEST , YOU CAN USED THEN ON WIDER SKIE FOR BEST FLOT.....
cat hunter
Like the man said!!!snowrider RX1ER said:EVERY ONE IN QUEBEC RIDE SNOWTRACKER
yamahammar
Thanks for the feedback
trailmarker
i run them on pilots, they are the extreem version and i have a 6' shaper bar on the outside. a little heavy stearing at slower speeds, but perfect at speed
Is Yamaha offering these this year thru the parts department?
cmharcou
I got pilot 5.7's on my Attak. It has dual carbides but I don't know what kind they are. They are needing replaced. Should I try these snowtrackers for my pilot 5.7s? I have an 07 Attak and Woodys studs.
- 7K
