YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
Well..
Going of everyone's reccomendations and getting a pair for my Apex GT. The only thing I have to say is that they are a bit pricey.
for an heavy machine they reccomend the Extreme Agressive
its
$228.92 for the pair
$26.00 shipping by UPS
Plus $ for custom duty paid
Plus Tax of your State
But it is cheaper than new skis
-Moose
its
-Moose
Kaz
YammiMoose said:Well..
its
-Moose
Royal Distributing sells them for $199.99 Cdn until December 1st, then their prices go up 10%
http://www.royaldistributing.com/Shoppi ... 9/237.html
I'm pretty sure I paid $159 for them last year.
Kaz
YammiMoose
- Mar 18, 2004
Kaz said:YammiMoose said:Well..
its
-Moose
Kaz
Thanks!
yamadog07
you won't regret it, they are awesome. i recomend the extremes.
Yeller
I bought a set after all the positive feedback I've heard. One question for those with them installed, where does the long plastic strip go? Does this go on first? What is its function?
The ones currently sold at Royal Distributing are the 3 blade. The new ones this year are 5 blade (two extra shorter fins at the back)
z28rx1
yeah, They work !!!!!
Another Phase
where does the long plastic strip go? Does this go on first? What is its function?[/quote]
Unless they've changed something, there is no plastic strip. You may be thinking of the flat metal plate with the wings and the long tip. You will have to drill an extra hole in the front of each ski for that tip to go in. The wings get rid of the darting by not allowing the runners to follow another skis ruts in the trail. The following carbide is free to carve it's own path.
attakred06
told you so
mine are half gone for 7500klm not so bad;;; they should come standard with your yamaha brand new;;;; anyway now i follow the trail
bye
attakred06
i ric ever heard of yammis superforum.com ????
attakred06
yammy moose where are you from,,could send them to you as a gift so no tax and custom???
Yeller
Another Phase said:where does the long plastic strip go? Does this go on first? What is its function?
Unless they've changed something, there is no plastic strip. You may be thinking of the flat metal plate with the wings and the long tip. You will have to drill an extra hole in the front of each ski for that tip to go in. The wings get rid of the darting by not allowing the runners to follow another skis ruts in the trail. The following carbide is free to carve it's own path.[/quote]
With each runner/plate combo I also recieved a long wide plastic strip about 1/8" thick and about 2" wide. It is quite a bit longer than the plate.
Another Phase
Not sure what that would be for. It didn't come with mine. Are there holes in it for the carbides to bolt through?
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
rik said:Another Phase said:where does the long plastic strip go? Does this go on first? What is its function?
With each runner/plate combo I also recieved a long wide plastic strip about 1/8" thick and about 2" wide. It is quite a bit longer than the plate.[/quote] With the trail kit you get the plastic strip. You should have gotten instruction's but i am quite sure the steel channel goes on first then the plastic and then the wear bar goes up through the whole thing with a bolt holding the front tight to the ski's. I had a pair of aggressive on my Apex last year and got a pair of trail for my Phazer that i don't have on yet. kviper
Another Phase
That makes sense. Mine were the aggressive. I guess only the trail version (semi aggressive) get the plastic strip.
- 17K
- 6K
