Blue shadow
Hey freddy,I do have your filter kit on from last year ,heavy hitters from Matt and a lot of little mods done.Center to center and off set with tentioners on both sides of motor.It made a new rx1 from stock.I am now setting up the tps that I can move manaully after 300 ft.I did try the evac kit last year 3 or 4 times the same day but it keeps putting oil in my carbs.It sputters on top end with it on.When it comes to geting me there faster I would try anything.If it works like it should ,what can I do to stop the oil from entering the cabs?THANKS
Did you try adding the stock catch box back to the system and then connect it to the evac?
one more thing if your passing enough oil that it's getting into the carbs you have a bigger problem
Blue shadow
No I did not,but I will.
- 9K
