straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
I'm in the process of changing the track on my 03 rx 1.The sled has 3300 miles on it and is new to me. I've had Polaris and cats in the past. My first Yamaha. The only Bearing showing wear is the upper chain case bearing. Why that bearing is not a sealed bearing is one ?. It's open to metal fillings from the chain.The bearing behind the secondary clutch to sealed and is fine.
The sleds I've had in the past at 3000 miles I've had to replace most of the skid bearings.This thing needs nothing. I've always changed out the drive bearing on the speedometer end of the drive shaft just because there cheep and I've had one fail back in the early 90s. The bearing on this Yamaha is different and seems fine. Never have changed any other bearing on the jack shaft or in the chain case.
So the only bearing that needs replacing as I see it is the one on the chain case side of the jack shaft. What your opinion? Change them all or just the bad one?Also. Do I go with a sealed bearing on top of the chain case? If not. How come?
And where is a good bearing dealer on line?
