Tried the re-wire, no good. Tried 2 kinds of hand guards no good. there has to be a way to make these stock grips work without expensive mods or swap outs? So many posts and so many different results.???? I never had cold hands even on my old 85 Phazer!!!!
motorman
hot grips
i replaced my grips ,and wired them the same as stock,and i can only run them on 4 bars they are so hot.i also filled mt bars with spray foam.
total investment about 50 to 60 dollars
OK, so what grips did you use?
Forget all of that, buy rockmeisters kit!! use all stock parts, quit throwing good money after bad..... his kit flat out works, my wife, who always runs her grips on full on hot, had to turn off rocks kit!
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
TonyVT said:Tried the re-wire, no good. Tried 2 kinds of hand guards no good. there has to be a way to make these stock grips work without expensive mods or swap outs? So many posts and so many different results.???? I never had cold hands even on my old 85 Phazer!!!!
Buy some gauntlets and your hands will be warm/hot...I only wear snowcross gloves on the coldest days/below zero
sobfrogg
TB151
seconded on gauntlets. I bust them out for those -20 days and they are AWESOME
ApexerER
I also got a set of gauntlets. They work great. It stinks that you have to use them because something as simple as handwarmers don't work but they do a great job. i just keep them in the nose of the sled and put them on if I get cold. I have ridden at -20F with them and my hands were warm.
Triple X
Yep, gauntlets for me also. Have had to use them every ride this winter. Tried to go without them last weekend and use Skinz hand guards, man what a mistake!
jkenosh
had skinz and they didnt work enough, i bought the gauntlets and love em
buy rocks kit, it works great. I do have guantlets for the frozen nights, not for the bars though, those will burn your hands off now. guantlets and guards are for the outside of my hands.
his kit works as good as the old 97 up style yamaha sleds grips worked, hand burners.
very well made. cant say enough good things about his service and product.
apex yooper
Gauntlets and mittens help, but fixing the sled is a better idea, and simple. Install 06 bars. Problem solved.
SLEDSTART
Did the 06 bars on mine but the hooks on the 06 bars are NOT heated. Solved this by putting the 07 bars back on and installing Rocks kit. ONLY WAY TO GO!!!!!!!
He was selling these things like candy at the Muni ride.
ANYONE who has it says it IS THE WAY TO GO.
I agree...
Rock ROCKS!
I agree...
Rock ROCKS!
attak-d
- Sep 20, 2006
- North Freedom,WI and Iron Belt,WI
Gauntlets!
schmeg
I did Dans mod using the 07 and later sublead with my 06 bars. 3 to 4 LED bars is all I ever need. Must of got lucky.
- 6K
