SnowdemonsRX1
I have these cr8e plugs, dont now why but i was wondering if i can run them in my 03' rx1
LazyBastard
Those are hotter plugs than recommended. Don't ever go over the heat range recommended. CR9E or 10 are ok. Yes, the higher the number the colder the plug.
SnowdemonsRX1
Thanks I should just throw them away. you the man LAZY
LazyBastard
Never throw away good plugs. You might need them one day.
SnowdemonsRX1
Just keep them as spares then
TonyVT
new plugs every year
So should the RX1 stock have new plugs every year? Comments? Thanks
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
14' KTM 500 EXC "SnowBike" fitted w/ 15' Timbersled LT
07' Phazer
No, unless you believe it isn't running it's best. These plugs should last 10,000 miles with out a hiccup. The bikes go 36,000 - 50,000 easy.
LazyBastard
Is that why mine fouled 2 plugs at 5000 miles?
