tmk50
I am going to install my extroverts on Sunday -
I've printed off the service manual pages and everything looks straightforward.
I did run across this tool on the MPI website ("RX1 top gear and jackshaft sprocket"
http://www.mountainperformance.com/yama ... _tools.htm
Quick sanity check please - all of you guys that have swapped tracks or changed drivers did not buy this $50 socket right?
:ORC
:ORC
you need a snapp ring tool.
LazyBastard
Its just a big hex socket... you can buy at home depot for $4. I think its 1 1/8 or 1 1/4 ish.
tmk50
Thanks Guys
Mountaintech
Its a very deep (long) socket. I borrowed one off of my dealer.
I have mine apart right now, I have the dealers tools right now. It is 36mm on the socket or for you std people very close to 1 7/16. There is 3" of shaft before the nut. Not sure on the torque spec.
snowy1
I just use a 12" cresent wrench works just fine.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
The tool Mountain offer's not only loosen's the nut it also hold's the shaft's while loosening the nut's. What i do to hold the shaft's is clip a vise grip with a rag on to the driven clutch lightly for leverage and then loosen both top and bottom sprocket's while the chain is still on.
RX Buck
- Sep 11, 2003
- Grand Rapids MN
- mobilepredictive.com
- 2017 Yamaha Sidewinder LTX
- MN
The 12" cresent wrench worked great for me also. You don't need a $30 socket.
LazyBastard
I think I just cranked mine with a vise grips on both ends. LOL.
